Ana içeriğe geç
Motorola Moto E4 Plus Daughterboard Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: adım 1, 3 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: adım 1, 3 resimden 2. Motorola Moto E4 Plus Daughterboard Replacement, Remove the back cover: adım 1, 3 resimden 3.
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Daughterboard Replacement: adım 2, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement: adım 2, 2 resimden 2.
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe screws: adım 3, 1 resimden 1.
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: adım 4, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Release the midframe clips: adım 4, 2 resimden 2.
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: adım 5, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the midframe: adım 5, 2 resimden 2.
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: adım 6, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the battery: adım 6, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: adım 7, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the antenna: adım 7, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the antenna cable from its daughterboard socket.
  8. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: adım 8, 3 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: adım 8, 3 resimden 2. Motorola Moto E4 Plus Daughterboard Replacement, Disconnect the daughterboard connectors: adım 8, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its daughterboard socket.
    • Pry up and disconnect the fingerprint sensor cable next to it from the daughterboard.
  9. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard screws: adım 9, 1 resimden 1.
    • Remove the two 3.2 mm long T3 screws securing the daughterboard.
  10. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: adım 10, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the daughterboard: adım 10, 2 resimden 2.
    • Insert the point of a spudger under the bottom right corner of the daughterboard and pry up to loosen the daughterboard.
  11. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: adım 11, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Loosen the vibration motor: adım 11, 2 resimden 2.
    • Insert the point of a spudger underneath the vibration motor and pry upwards to loosen it.
  12. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: adım 12, 2 resimden 1. Motorola Moto E4 Plus Daughterboard Replacement, Remove the daughterboard: adım 12, 2 resimden 2.
    • Grasp the daughterboard by the edges and lift it out of its recess.
    • Remove the daughterboard. The vibration motor will be attached to it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
258.916 İtibar
531 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.083 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,516
