Ana içeriğe geç
Motorola Moto E4 Vibrator Replacement
Neye ihtiyacın var
  1. Motorola Moto E4 Vibrator Replacement, Remove the rear cover: adım 1, 2 resimden 1. Motorola Moto E4 Vibrator Replacement, Remove the rear cover: adım 1, 2 resimden 2.
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Vibrator Replacement, Charging Port: adım 2, 1 resimden 1.
    • Remove the six 4mm screws from the bottom plastic cover with a Phillips driver bit.
  3. Motorola Moto E4 Vibrator Replacement: adım 3, 1 resimden 1.
    • Gently pry the plastic cover from the phone using an iFixit opening tool.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Vibrator Replacement: adım 4, 3 resimden 1. Motorola Moto E4 Vibrator Replacement: adım 4, 3 resimden 2. Motorola Moto E4 Vibrator Replacement: adım 4, 3 resimden 3.
    • Detach the two ribbon cable connectors from the top of the board using an iFixit opening tool.
    • Unplug the antenna cable connector from the board using an iFixit opening tool.
  5. Motorola Moto E4 Vibrator Replacement: adım 5, 3 resimden 1. Motorola Moto E4 Vibrator Replacement: adım 5, 3 resimden 2. Motorola Moto E4 Vibrator Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
  6. Motorola Moto E4 Vibrator Replacement: adım 6, 2 resimden 1. Motorola Moto E4 Vibrator Replacement: adım 6, 2 resimden 2.
    • Remove the two 4mm silver screws holding down the charging port board with Phillips bit.
  7. Motorola Moto E4 Vibrator Replacement: adım 7, 2 resimden 1. Motorola Moto E4 Vibrator Replacement: adım 7, 2 resimden 2.
    • Place the iFixit opening tool underneath the board in between the micro USB port and the microphone.
    • Push forward and lift gently until the board lifts up.
    • Remove the charging port board from the device.
  8. Motorola Moto E4 Vibrator Replacement, Vibrator: adım 8, 2 resimden 1. Motorola Moto E4 Vibrator Replacement, Vibrator: adım 8, 2 resimden 2.
    • Gently pull the vibrator upwards to remove the vibrator wires from the silver clasp holding the wires to the board.
    • Pull directly upwards to remove the vibrator from its connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nate Tjepkema
1.254 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G4, White Winter 2019 Cal Poly, Team S2-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S2G4
4 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 607
