Ana içeriğe geç
Motorola Moto E6 Charging Dock Replacement
Neye ihtiyacın var
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto E6 Charging Dock Replacement, Back Cover: adım 1, 2 resimden 2.
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: adım 2, 1 resimden 1.
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: adım 3, 1 resimden 1.
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: adım 4, 1 resimden 1.
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: adım 5, 1 resimden 1.
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: adım 6, 1 resimden 1.
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Matthew Zelten
471 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 üyesi
CPSU-WHITE-W20S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 29
Her zaman: 3,099
