Ana içeriğe geç
Motorola Moto E6 Rear Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto E6 Rear Facing Camera Replacement, Back Cover: adım 1, 2 resimden 2.
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Rear Facing Camera Replacement, Battery: adım 2, 1 resimden 1.
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Rear Facing Camera Replacement, Motherboard: adım 3, 1 resimden 1.
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Rear Facing Camera Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Rear Facing Camera Replacement: adım 5, 1 resimden 1.
    • Remove the two 1.1 mm T4 Torx screws from the bottom left and top right sides of the motherboard.
  6. Motorola Moto E6 Rear Facing Camera Replacement: adım 6, 1 resimden 1.
    • Remove the two press fit cables at the bottom of the motherboard with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
    • After removing the cables, remove the motherboard from the phone by hand.
  7. Motorola Moto E6 Rear Facing Camera Replacement, Rear Facing Camera: adım 7, 1 resimden 1.
    • Remove the press fit cable using the plastic opening tool, and remove the camera from the phone.
Sonuç
Christopher Hoefer
197 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, White Winter 2020 Cal Poly, Team S2-G3, White Winter 2020 üyesi
CPSU-WHITE-W20S2G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 669
