Ana içeriğe geç
Motorola Moto E6 Speaker Replacement
Neye ihtiyacın var
  1. Motorola Moto E6 Speaker Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto E6 Speaker Replacement, Back Cover: adım 1, 2 resimden 2.
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Speaker Replacement, Battery: adım 2, 1 resimden 1.
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove the eleven 3.8 mm T4 Torx screws located above the battery compartment.
  4. Motorola Moto E6 Speaker Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tools to pry open the piece located at the top of the device.
    • Start by prying open the side of the compartment and work your way towards the camera module, prying open the compartment as you go.
    • Pop off the piece above the battery compartment.
  5. Motorola Moto E6 Speaker Replacement: adım 5, 3 resimden 1. Motorola Moto E6 Speaker Replacement: adım 5, 3 resimden 2. Motorola Moto E6 Speaker Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Using tweezers, lift the speaker from the motherboard located at the top of the device.
    • When replacing with a new component, make sure the clips are facing towards the user.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,233
