Giriş
This guide will teach you how to replace the motherboard in your Moto G, in the event that it is malfunctioning. It may take a while, since the battery and SD/SIM card reader must be removed first, but all you will need are a T5 Torx screwdriver and a plastic opening tool.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Neye ihtiyacın var
Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
Work your way down the sides to avoid cracking the rear cover.
Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
Using the same screwdriver, remove the six 3.2 mm screws on the sides.
Remove the next layer of the phone by prying it off with your fingers.
On mine, they’re all Torx T5
You neglected to mention that the two buttons might fall out when you remove this part.
Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
Disconnect the battery connector by prying it off of the motherboard.
Disconnect the vibration motor by prying its connector off of the motherboard.
There's no need to remove the battery or motherboard to get to the speakers - they are accessible as soon as the back cover is removed. Skip this step and jump straight to step 10
In fact it is not necessary to remove the simcard rack. I managed to remove battery with the rack on. It is possible to remove the foil startingfrom the bottom of the battery and once peeled off the battery can be removed. You only need to disconnect the battery from the mother board.
Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
As mentioned in a comment on the previous step, you don’t actually need to remove the SIM/SD card reader at all.
If you peel back the copper foil from the opposite end of the device, you can sneak the battery out (and the new battery in) by just sliding the battery ribbon cable out from under the SIM/SD card reader.
Thx for the idea. I’ll let you know if it was working - I’ll my battery soon. regards!
Perfect as mentioned - just slide the cable foil under the sim rack - no need to remove the rack. Works flawlessly, quick repair.
Peel off the two black stickers on the right side of the battery using your fingers.
Remove the battery by pulling the right side of it upwards.
If the copper foil is damaged beyond repair, what can be used to replace it?
Carefully remove the motherboard.
30 farklı kişi bu kılavuzu tamamladı.
4 Yorum
What about Android, it comes already flashed on a new motherboard or I need to flash it myself?
Where can i buy mother board for moto g 2nd gen lte. Any idea?
Important - remove SIM cards before opening the phone.
Wojciech Dyba - Yanıt
