Ana içeriğe geç
Motorola Moto G 3rd Generation Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement, Display: adım 1, 2 resimden 1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement, Display: adım 1, 2 resimden 2.
    • Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
    • Make sure to fully power off the phone before you begin disassembly.
  2. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 2, 2 resimden 1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 2, 2 resimden 2.
    • Use a heat gun or an iOpener as a heating tool. This guide explains how to use the iOpener.
    • Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
    • Do not let the iOpener/heat gun remain on one spot for too long. Excess heat can damage the phone.
    • When reassembling the phone, use the iOpener/heat gun to help the adhesive fuse to the new screen. Heat the screen edges, apply pressure to the screen, and hold the screen in place until it is secure.
  3. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 3, 3 resimden 1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 3, 3 resimden 2. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 3, 3 resimden 3.
    • As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
    • Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
    • Avoid damaging the LCD screen connector while prying along the screen edges. It is located on the left edge of the phone, across from the volume controls.
    • During reassembly, new adhesive may need to be applied over the old adhesive to properly secure the screen.
  4. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 4, 3 resimden 1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 4, 3 resimden 2. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $5.99
    • Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
    • When installing a new display, carefully remove all remaining adhesive from the phone, and clean the adhered areas with isopropyl alcohol (90% or greater) and a lint-free cloth. Install the display using pre-cut adhesive or a strong double-sided tape such as Tesa 61395. Turn your phone on and test your repair before sealing the display in place.
  5. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
    • Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
  6. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 6, 1 resimden 1.
    • If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
    • Carefully lift the right edge of the motherboard from the phone.
    • Avoid pulling on the battery wires, which connect the left underside of the motherboard to the battery.
  7. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 7, 1 resimden 1.
    • Use a plastic opening tool to disconnect the battery wires from the motherboard.
  8. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement, SIM/SD Card Reader PCB: adım 8, 1 resimden 1.
    • Remove the three 2.4 mm T4 screws from the right side and bottom of the SIM/SD card panel.
  9. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 9, 1 resimden 1.
    • Pry off the SIM/SD card panel using a plastic opening tool.
    • There may be adhesive securing the SIM/SD card panel to the motherboard. Exercise caution when prying it off.
    • Replace the adhesive when inserting a new card panel.
  10. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement, Rear-Facing Camera: adım 10, 1 resimden 1.
    • Pry off the main camera from its base using a plastic opening tool.
  11. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 11, 2 resimden 1. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 11, 2 resimden 2.
    • Use a plastic opening tool to flip up the lock on the camera cable ZIF connector.
  12. Motorola Moto G 3rd Generation Rear-Facing Camera Replacement: adım 12, 1 resimden 1.
    • Carefully pull the camera from its socket on the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
James Copeland
4.043 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Nance Spring 2016 USF Tampa, Team 1-3, Nance Spring 2016 üyesi
USFT-NANCE-S16S1G3
4 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 3,905
