Neye ihtiyacın var
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use a plastic opening tool to remove the protective cover.
7 farklı kişi bu kılavuzu tamamladı.
