Ana içeriğe geç
Motorola Moto G4 Lens Replacement
Neye ihtiyacın var
  1. Motorola Moto G4 Lens Replacement, Lens: adım 1, 2 resimden 1. Motorola Moto G4 Lens Replacement, Lens: adım 1, 2 resimden 2.
    • Place your thumb in the indent located at bottom left corner of the back cover.
    • The cover will pop up and begin to lift
    • Continue to slide your fingers up the sides to remove the back cover
  2. Motorola Moto G4 Lens Replacement: adım 2, 2 resimden 1. Motorola Moto G4 Lens Replacement: adım 2, 2 resimden 2.
    • Remove the gray plastic surrounding the camera lens with a pair of tweezers.
    • There will be a lot of glue and you may have to pull hard on the plastic piece
  3. Motorola Moto G4 Lens Replacement: adım 3, 2 resimden 1. Motorola Moto G4 Lens Replacement: adım 3, 2 resimden 2.
    • Slide a pair of tweezers under and around the lens to loosen it.
    • Pulls the lens towards you to remove.
    • There will be glue under the lens. You may have to pull hard to remove the lens
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kierra Schau
1.511 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G2, Passmore Fall 2017 USF Tampa, Team S11-G2, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S11G2
3 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,975
