Ana içeriğe geç
Motorola Moto G4 Play Battery Replacement
Neye ihtiyacın var
  1. Motorola Moto G4 Play Battery Replacement, Battery: adım 1, 3 resimden 1. Motorola Moto G4 Play Battery Replacement, Battery: adım 1, 3 resimden 2. Motorola Moto G4 Play Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Battery Replacement: adım 2, 3 resimden 1. Motorola Moto G4 Play Battery Replacement: adım 2, 3 resimden 2. Motorola Moto G4 Play Battery Replacement: adım 2, 3 resimden 3.
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Battery Replacement: adım 3, 3 resimden 1. Motorola Moto G4 Play Battery Replacement: adım 3, 3 resimden 2. Motorola Moto G4 Play Battery Replacement: adım 3, 3 resimden 3.
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Paola Rossi
487 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G4, Boczar Spring 2018 USF Tampa, Team S17-G4, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G4
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Precio de la bateria
Elimar Johana Lugo Gil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 4,647
