Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
Lift the case by the nearest corner to the divot and remove it from the phone.
Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
Remove battery from your phone.
Remove any SIM card and/or memory card present using your hand.
Bu adımda kullanılan alet:Tweezers$4.99-
Remove the small silicon cover at the bottom right of the camera using tweezers.
Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
