Giriş
Use this guide to replace a broken or malfunctioning screen. When removing the screen, make sure to wear safety glasses.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Note: Microwave only one iOpener at a time for no more than 30 seconds, and make sure to not microwave it more than once within two minutes.
Neye ihtiyacın var
Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
Remove the small silicon cover at the bottom right of the camera using tweezers.
I eventually gave up trying to peel it back and just brute-forced a small hole large enough to get to the screw. Slightly less waterproof now :)
Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
Pop up on the vibrator's connector to separate it from the charging port.
Putting this tiny connector back in will be the hardest part of the process. I wish I had a magnifier handy when I did this because my eyes aren’t what they used to be. Very tiny part!
Using an opening tool, pry up one of the connectors to the left of where the sim card was located.
Using the plastic opening tool, carefully pry up the motherboard.
Bu adımda kullanılan alet:Plastic Cards$2.99
Insert the Jimmy knife through the edge.
Place a plastic card so that the adhesive doesn't stick back again.
Go around the edges of the device with the Jimmy knife until all the adhesive has been removed.
9 farklı kişi bu kılavuzu tamamladı.
4 Yorum
The smaller one is from the power and Volume buttons and needs tobe transfered to the new display if you bought one with Frame (which makes it much easier)
I had to figure out that out myself. Yes, you will need to transfer the connector from the old frame to the new frame. I should also add, the frame I got had no buttons, so I had to get them from the old phone.
Good guide though I could not see the purpose of removing items 20, 21 & 22
