Ana içeriğe geç
Motorola Moto G5 Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto G5 Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto G5 Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Motherboard Replacement: adım 2, 3 resimden 1. Motorola Moto G5 Motherboard Replacement: adım 2, 3 resimden 2. Motorola Moto G5 Motherboard Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Motherboard Replacement: adım 3, 3 resimden 1. Motorola Moto G5 Motherboard Replacement: adım 3, 3 resimden 2. Motorola Moto G5 Motherboard Replacement: adım 3, 3 resimden 3.
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Motherboard Replacement: adım 4, 2 resimden 1. Motorola Moto G5 Motherboard Replacement: adım 4, 2 resimden 2.
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Motherboard Replacement, Battery: adım 5, 2 resimden 1. Motorola Moto G5 Motherboard Replacement, Battery: adım 5, 2 resimden 2.
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: adım 7, 2 resimden 1. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: adım 7, 2 resimden 2.
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Motherboard Replacement: adım 8, 3 resimden 1. Motorola Moto G5 Motherboard Replacement: adım 8, 3 resimden 2. Motorola Moto G5 Motherboard Replacement: adım 8, 3 resimden 3.
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Motherboard Replacement: adım 9, 3 resimden 1. Motorola Moto G5 Motherboard Replacement: adım 9, 3 resimden 2. Motorola Moto G5 Motherboard Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Motherboard Replacement: adım 12, 1 resimden 1.
    Satın Al
    • Unplug the back connector from the motherboard using tweezers.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Luis Garcia
307 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G3
4 Üyeler
16 adet Kılavuz yazıldı
2 Yorum
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - Yanıt
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 47
Her zaman: 6,327
