Ana içeriğe geç
Motorola Moto G5 Vibration Motor Replacement
Neye ihtiyacın var
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: adım 1, 2 resimden 2.
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: adım 2, 3 resimden 1. Motorola Moto G5 Vibration Motor Replacement: adım 2, 3 resimden 2. Motorola Moto G5 Vibration Motor Replacement: adım 2, 3 resimden 3.
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: adım 3, 3 resimden 1. Motorola Moto G5 Vibration Motor Replacement: adım 3, 3 resimden 2. Motorola Moto G5 Vibration Motor Replacement: adım 3, 3 resimden 3.
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: adım 4, 2 resimden 1. Motorola Moto G5 Vibration Motor Replacement: adım 4, 2 resimden 2.
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: adım 5, 2 resimden 1. Motorola Moto G5 Vibration Motor Replacement, Battery: adım 5, 2 resimden 2.
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: adım 6, 1 resimden 1.
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: adım 7, 1 resimden 1.
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: adım 8, 1 resimden 1.
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: adım 9, 3 resimden 1. Motorola Moto G5 Vibration Motor Replacement: adım 9, 3 resimden 2. Motorola Moto G5 Vibration Motor Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: adım 10, 1 resimden 1.
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: adım 11, 1 resimden 1.
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Miles Cobb
371 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S2G3
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Is this also where the mic is located?
Matt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 3,452
