Ana içeriğe geç
Motorola Moto G5s Plus Battery Replacement
Neye ihtiyacın var
  1. Motorola Moto G5s Plus Battery Replacement, Display: adım 1, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement, Display: adım 1, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement, Display: adım 1, 3 resimden 3.
    • Power off the phone before you begin.
    • Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
    • Spend equal amounts of time applying heat around the entire edge of the phone.
  2. Motorola Moto G5s Plus Battery Replacement: adım 2, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 2, 2 resimden 2.
    • Attach the suction cup to the display slightly to the left of center.
    • Exert a moderate force to pull on the suction cup. The display will come loose.
  3. Motorola Moto G5s Plus Battery Replacement: adım 3, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 3, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement: adım 3, 3 resimden 3.
    • Insert the opening tool inside the loosened edge.
    • Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
    • Do not wedge the opening tool too far beneath the screen. Using too much force can result in torn connector cables.
  4. Motorola Moto G5s Plus Battery Replacement: adım 4, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 4, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement: adım 4, 3 resimden 3.
    • The display should now be entirely loose, attached only by the connectors at the top of the device and the fingerprint sensor connector at the bottom of the device.
    • Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
    • If the fingerprint sensor does not come loose, use the heat gun to loosen its adhesive.
  5. Motorola Moto G5s Plus Battery Replacement: adım 5, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 5, 2 resimden 2.
    • The cables at the top of the device are fragile. If you are using this guide as a prerequisite for replacing another part, be careful not to tear the cables while lifting the screen.
    • Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
  6. Motorola Moto G5s Plus Battery Replacement: adım 6, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Grab the unscrewed metal plate with your blunt tweezers.
    • Slide the metal plate to the left and then out to remove it.
    • Removing the plate will expose the display assembly's connection to the phone's motherboard.
  7. Motorola Moto G5s Plus Battery Replacement: adım 7, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 7, 2 resimden 2.
    • Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
  8. Motorola Moto G5s Plus Battery Replacement: adım 8, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 8, 2 resimden 2.
    • Lift up the detached right connector from its housing using blunt tweezers.
    • The housing has light adhesive underneath it. Use a small amount of force to remove the connector from the housing.
  9. Motorola Moto G5s Plus Battery Replacement, Fingerprint Sensor: adım 9, 1 resimden 1.
    • Remove the nine black 5mm Torx-5 screws.
    • Remove the seven silver 5mm Torx-5 screws.
  10. Motorola Moto G5s Plus Battery Replacement: adım 10, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 10, 2 resimden 2.
    • Remove the metal cover by prying underneath it with the opening tool.
  11. Motorola Moto G5s Plus Battery Replacement: adım 11, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 11, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement: adım 11, 3 resimden 3.
    • Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
  12. Motorola Moto G5s Plus Battery Replacement: adım 12, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 12, 2 resimden 2.
    • Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
  13. Motorola Moto G5s Plus Battery Replacement, Battery: adım 13, 1 resimden 1.
    • The battery is now fully exposed and ready to be removed.
  14. Motorola Moto G5s Plus Battery Replacement: adım 14, 2 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 14, 2 resimden 2.
    • Use the opening tool to remove the two metal connectors located above the battery.
    • Apply a gentle upward pressure to loosen the metal plates.
  15. Motorola Moto G5s Plus Battery Replacement: adım 15, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 15, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement: adım 15, 3 resimden 3.
    • Using the spudger, cut downwards along the black tape on left side of the battery.
  16. Motorola Moto G5s Plus Battery Replacement: adım 16, 1 resimden 1.
    • Use the opening tool to disengage the black connector located above the battery.
  17. Motorola Moto G5s Plus Battery Replacement: adım 17, 1 resimden 1.
    • Heating up the battery excessively could cause the battery to ignite
    • Use the heat gun along the back of the phone to loosen the adhesive that holds the battery in place.
    • Spend equal intervals of time on each area applying heat.
  18. Motorola Moto G5s Plus Battery Replacement: adım 18, 3 resimden 1. Motorola Moto G5s Plus Battery Replacement: adım 18, 3 resimden 2. Motorola Moto G5s Plus Battery Replacement: adım 18, 3 resimden 3.
    • Insert the spudger underneath the right side of the battery.
    • Apply a moderate upward force along the length of battery, until the battery lifts out of place.
    • Remove the battery with your hand.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Kevin George
1.099 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S4-G5, White Fall 2018 Cal Poly, Team S4-G5, White Fall 2018 üyesi
CPSU-WHITE-F18S4G5
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
Hello,
I would like to chance the battery.
But for me it isn’t not clear how to glue the screen back again. I can not find any sealing at the market
Thanks
Jirik - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 13,255
