Ana içeriğe geç
Motorola Moto G7 Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Motherboard Replacement, Screen: adım 1, 3 resimden 1. Motorola Moto G7 Motherboard Replacement, Screen: adım 1, 3 resimden 2. Motorola Moto G7 Motherboard Replacement, Screen: adım 1, 3 resimden 3.
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Motherboard Replacement: adım 2, 1 resimden 1.
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Motherboard Replacement: adım 3, 2 resimden 1. Motorola Moto G7 Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Motherboard Replacement: adım 4, 3 resimden 1. Motorola Moto G7 Motherboard Replacement: adım 4, 3 resimden 2. Motorola Moto G7 Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
  5. Motorola Moto G7 Motherboard Replacement, Camera: adım 5, 3 resimden 1. Motorola Moto G7 Motherboard Replacement, Camera: adım 5, 3 resimden 2. Motorola Moto G7 Motherboard Replacement, Camera: adım 5, 3 resimden 3.
    • Remove by the six 2.7mm T3 Torx screws from the metal panel above the battery.
    • Wedge a spudger between the SD card tray and the metal plate, and use a medium amount of force to pry up the plate.
  6. Motorola Moto G7 Motherboard Replacement: adım 6, 1 resimden 1.
    • Use a spudger beneath the right side of the connector to detach it.
  7. Motorola Moto G7 Motherboard Replacement: adım 7, 3 resimden 1. Motorola Moto G7 Motherboard Replacement: adım 7, 3 resimden 2. Motorola Moto G7 Motherboard Replacement: adım 7, 3 resimden 3.
    • Detach the two small black and white connectors on either side of the camera using a spudger.
    • Remove the camera from the smartphone.
  8. Motorola Moto G7 Motherboard Replacement, Speaker: adım 8, 3 resimden 1. Motorola Moto G7 Motherboard Replacement, Speaker: adım 8, 3 resimden 2. Motorola Moto G7 Motherboard Replacement, Speaker: adım 8, 3 resimden 3.
    • Remove three 3.7mm T3 Torx screws from the bottom of the phone.
    • Use the spudger to gently lift the speaker out of the phone.
  9. Motorola Moto G7 Motherboard Replacement, Motherboard: adım 9, 3 resimden 1. Motorola Moto G7 Motherboard Replacement, Motherboard: adım 9, 3 resimden 2. Motorola Moto G7 Motherboard Replacement, Motherboard: adım 9, 3 resimden 3.
    • Use the SIM card removal bit to remove the SIM card tray.
  10. Motorola Moto G7 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the fingerprint scanner connector from the motherboard by levering the spudger underneath the connector corner.
  11. Motorola Moto G7 Motherboard Replacement: adım 11, 1 resimden 1.
    • Use a T3 Torx screwdriver to remove the four 2.3mm screws from the bottom and right sides of the phone.
  12. Motorola Moto G7 Motherboard Replacement: adım 12, 2 resimden 1. Motorola Moto G7 Motherboard Replacement: adım 12, 2 resimden 2.
    • Lever the spudger underneath the motherboard above the battery.
    • Use a medium amount of force to remove the motherboard from the rest of the phone assembly.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jonathan Doubt
226 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2020 Cal Poly, Team S19-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S19G6
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
You forgot about removing the little cable on the right side of the motherboard. About 1/4 down the board up against the outside of the case. It's one of those Zero Force cables.
Right below the SIM card holder.
Above the highest black chip.
And to the left of the second screw hole
(from the top).
You can see it in the picture
stanbudz44 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 45
Her zaman: 3,520
