Giriş
This guide will show each detailed step to removing and replacing the battery in the Motorola G7 Play, model number XT1952-3 or XT1952-2. The battery is what keeps the device powered when disconnected from a charger. If the device does not power on or does not hold a charge this can possibly mean that the battery is no longer working. Look out for a swollen or leaking battery. If there is a swollen or leaking battery, be cautious and follow iFixit’s guide on what to do if a battery is swollen.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Neye ihtiyacın var
Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
Press the tool into the hole to eject the tray.
Remove SIM Card Tray.
14 farklı kişi bu kılavuzu tamamladı.
6 Yorum
I found this useful although I was dismantling a G7 Power. The screws are in different places but most parts and the the battery are the same or similar. Fortunately, though I discovered that steps 8, 9 and 13 were unnecessary. The motherboard and charging boards could be left in place (only the plastic covers had to come off) while the battery was removed.
I successfully changed a battery on a G7 Play. I skipped steps 4, 7, 8, 10, 11, 12, 13, 14, and 15. The instructions for removing the battery are risky. I pried the battery up a little and put constant pressure on it until it came loose which took about 60 seconds. The battery comes with a tiny connector at the end of a ribbon cable. This is plugged into a board, and then the motherboard holds it in place. In general, the phone is not designed for the battery to be replaced which surprised me.
Thank you! I successfully disassembled my G7 Play after an unfortunate dive in a lake to let it completely dry. It's now working as new!
