Ana içeriğe geç
Motorola Moto G7 Play Battery Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Play Battery Replacement, Battery: adım 1, 2 resimden 1. Motorola Moto G7 Play Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off device before you begin.
    • Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
    • Press the tool into the hole to eject the tray.
    • Remove SIM Card Tray.
  2. Motorola Moto G7 Play Battery Replacement: adım 2, 2 resimden 1. Motorola Moto G7 Play Battery Replacement: adım 2, 2 resimden 2.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case.
  3. Motorola Moto G7 Play Battery Replacement: adım 3, 1 resimden 1.
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  4. Motorola Moto G7 Play Battery Replacement: adım 4, 2 resimden 1. Motorola Moto G7 Play Battery Replacement: adım 4, 2 resimden 2.
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  5. Motorola Moto G7 Play Battery Replacement: adım 5, 1 resimden 1.
    • Next, remove the nine 3.2mm Phillips #00 screws from the motherboard cover with a 00 Phillips bit.
  6. Motorola Moto G7 Play Battery Replacement: adım 6, 1 resimden 1.
    • Lift the motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed.
  7. Motorola Moto G7 Play Battery Replacement: adım 7, 3 resimden 1. Motorola Moto G7 Play Battery Replacement: adım 7, 3 resimden 2. Motorola Moto G7 Play Battery Replacement: adım 7, 3 resimden 3.
    • Using an iFixit opener tool, detach the fingerprint sensor and the other 5 cables from the motherboard.
  8. Motorola Moto G7 Play Battery Replacement: adım 8, 1 resimden 1.
    • Remove the 0.4mm Phillips #00 screw from the motherboard with a 00 Phillips bit.
  9. Motorola Moto G7 Play Battery Replacement: adım 9, 1 resimden 1.
    • Carefully pry up the motherboard from the bottom with an iFixit opener tool.
  10. Motorola Moto G7 Play Battery Replacement: adım 10, 1 resimden 1.
    • Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
    • Remove the cover.
  11. Motorola Moto G7 Play Battery Replacement: adım 11, 1 resimden 1.
    • Using the iFixit opening tool, carefully pry up the charging port assembly cover.
  12. Motorola Moto G7 Play Battery Replacement: adım 12, 2 resimden 1. Motorola Moto G7 Play Battery Replacement: adım 12, 2 resimden 2.
    • Using an iFixit opening tool, detach the cables from the charging port assembly.
  13. Motorola Moto G7 Play Battery Replacement: adım 13, 1 resimden 1.
    • Using the iFixit opening tool, carefully pry up the charging port assembly.
  14. Motorola Moto G7 Play Battery Replacement: adım 14, 3 resimden 1. Motorola Moto G7 Play Battery Replacement: adım 14, 3 resimden 2. Motorola Moto G7 Play Battery Replacement: adım 14, 3 resimden 3.
    • Using a spudger, break both adhesive strips on the back side of the battery.
    • Using a metal spudger may puncture or damage other components in your device.
  15. Motorola Moto G7 Play Battery Replacement: adım 15, 1 resimden 1.
    • Pry the battery up now that the adhesive has been separated from the battery.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Monserath Casillas
1.146 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G4
5 Üyeler
12 adet Kılavuz yazıldı
6 Yorum
I found this useful although I was dismantling a G7 Power. The screws are in different places but most parts and the the battery are the same or similar. Fortunately, though I discovered that steps 8, 9 and 13 were unnecessary. The motherboard and charging boards could be left in place (only the plastic covers had to come off) while the battery was removed.
keithmoseley - Yanıt
I successfully changed a battery on a G7 Play. I skipped steps 4, 7, 8, 10, 11, 12, 13, 14, and 15. The instructions for removing the battery are risky. I pried the battery up a little and put constant pressure on it until it came loose which took about 60 seconds. The battery comes with a tiny connector at the end of a ribbon cable. This is plugged into a board, and then the motherboard holds it in place. In general, the phone is not designed for the battery to be replaced which surprised me.
Joe Doll - Yanıt
Thank you! I successfully disassembled my G7 Play after an unfortunate dive in a lake to let it completely dry. It's now working as new!
Matthieu Bister - Yanıt
I followed all the steps and my phone will do nothing. Like it has no power any
Any suggestions?
hodgine - Yanıt
I wouldn't recommend doing this. I somehow managed to disable the touchscreen attempting it myself and basically bricked my phone.
Shawn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 44
Son 30 gün: 168
Her zaman: 25,408
