Ana içeriğe geç
Motorola Moto G7 Play Motherboard Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Play Motherboard Replacement, Back Cover: adım 1, 2 resimden 1. Motorola Moto G7 Play Motherboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Motherboard Replacement: adım 2, 1 resimden 1.
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Motherboard Replacement: adım 3, 2 resimden 1. Motorola Moto G7 Play Motherboard Replacement: adım 3, 2 resimden 2.
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Motherboard Replacement: adım 6, 2 resimden 1. Motorola Moto G7 Play Motherboard Replacement: adım 6, 2 resimden 2.
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  7. Motorola Moto G7 Play Motherboard Replacement: adım 7, 2 resimden 1. Motorola Moto G7 Play Motherboard Replacement: adım 7, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Monserath Casillas
1.146 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 üyesi
CPSU-REGAN-W20S7G4
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 26
Her zaman: 2,179
