Giriş
This guide’s easy to follow steps show how to replace the rear camera of the Motorola Moto G7 Plus (model XT1965). The default camera is 16-megapixel, with f1.7 aperture, object image stabilization, and a 2160p video recording at 30 fps camera. This is denoted by the circular glass on the back of the phone.
Before starting the repair, check the list of tools that you will need. To replace the camera, a new compatible camera will also be needed.
Ensure the device is turned off and not connected to any power sources.
Parçalar
Hiçbir parça belirtilmedi.
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
Once enough adhesive has been removed, you should be able to separate the screen, gently lifting from the left side of the phone.
Use the spudger to carefully slice through the black adhesive.
Use a Torx T5 screwdriver to remove the four 2.7mm screws.
