Giriş
This guide for the Motorola Moto G7 Plus (model XT1965) shows easy to follow steps on how to replace the fingerprint sensor on the back of the phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
The fingerprint sensor identifies the user in order to unlock the phone, make secure online purchases, and sign into apps.
Before starting the repair, check the list of tools that you will need. Be careful when removing the adhesive from the back of the phone and when removing the sensor. Ensure the device is completely turned off and not connected to any power sources.
Neye ihtiyacın var
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone while placing them in the corners.
After placing the picks along the edge of the screen, refer to step 2.
Bir başkası bu kılavuzu tamamladı.
3 Yorum
Hello, the connector of the fingerprint scanner isn’t actually detachable from the back. In order to reach it you need to take the screen off, so this tutorial is only partially helpful for fixing the fingerprint scanner.
hello y need a original battery cover for my motorola moto g7 plus can you help me $g$
Where can I order the sensor from?
