Giriş
If the power or volume buttons for the Motorola Moto G7 Plus are not functioning properly - sticky, will not register on the phone - use this guide to replace the buttons.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
The power and volume buttons toggle the power and control the volume level on the phone respectively. Faulty volume and power buttons can lead to loss of control over the power and volume of the phone.
Neye ihtiyacın var
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone while placing them in the corners.
After placing the picks along the edge of the screen, refer to step 2.
Use the pick to pry off the white plastic piece that holds the volume and power buttons in place.
Bir başkası bu kılavuzu tamamladı.
