Ana içeriğe geç
Motorola Moto G7 Plus Speaker Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: adım 1, 2 resimden 1. Motorola Moto G7 Plus Speaker Replacement, Remove the Screen: adım 1, 2 resimden 2.
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: adım 2, 2 resimden 1. Motorola Moto G7 Plus Speaker Replacement, Remove the Display Cable Cover: adım 2, 2 resimden 2.
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Speaker Replacement: adım 3, 2 resimden 1. Motorola Moto G7 Plus Speaker Replacement: adım 3, 2 resimden 2.
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: adım 4, 2 resimden 1. Motorola Moto G7 Plus Speaker Replacement, Separate the Display From the Phone: adım 4, 2 resimden 2.
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Speaker Replacement, Speaker: adım 5, 2 resimden 1. Motorola Moto G7 Plus Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
  6. Motorola Moto G7 Plus Speaker Replacement: adım 6, 3 resimden 1. Motorola Moto G7 Plus Speaker Replacement: adım 6, 3 resimden 2. Motorola Moto G7 Plus Speaker Replacement: adım 6, 3 resimden 3.
    • Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
    • A medium amount of force may be required.
Sonuç
Javier Guerra
301 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G5, Regan Winter 2020 Cal Poly, Team S22-G5, Regan Winter 2020 üyesi
CPSU-REGAN-W20S22G5
5 Üyeler
17 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 2,399
