Ana içeriğe geç
Motorola Moto G7 Screen Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Screen Replacement, Screen: adım 1, 3 resimden 1. Motorola Moto G7 Screen Replacement, Screen: adım 1, 3 resimden 2. Motorola Moto G7 Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Screen Replacement: adım 2, 1 resimden 1.
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Screen Replacement: adım 3, 2 resimden 1. Motorola Moto G7 Screen Replacement: adım 3, 2 resimden 2.
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Screen Replacement: adım 4, 3 resimden 1. Motorola Moto G7 Screen Replacement: adım 4, 3 resimden 2. Motorola Moto G7 Screen Replacement: adım 4, 3 resimden 3.
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Peter Nelson
742 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2020 Cal Poly, Team S19-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S19G6
4 Üyeler
20 adet Kılavuz yazıldı
3 Yorum
The replacement part listed here on iFixit indicates installation adhesive is not included. Can you reuse the adhesive on the old part? If not, what adhesive is recommended for this type of repair?
Gabe LaBounty - Yanıt
You can’t. I used the 1 mil tape and it worked.
Javier Vilalta - Yanıt
How much would it cost to send this in for someone else to put in a new screen?
Nathaniel Mcvay - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 95
Her zaman: 11,965
