Ana içeriğe geç
Motorola Moto G7 Speaker Replacement
Neye ihtiyacın var
  1. Motorola Moto G7 Speaker Replacement, Screen: adım 1, 3 resimden 1. Motorola Moto G7 Speaker Replacement, Screen: adım 1, 3 resimden 2. Motorola Moto G7 Speaker Replacement, Screen: adım 1, 3 resimden 3.
    • Use the iFixit opening tools to gently wedge the front screen from the rest of the device.
    • Try to focus on the corners to make it easier to insert and use the iFixit opening picks.
    • It is also recommended to use the iOpener or a heat gun to weaken the adhesive that holds the edges of the screen down.
    • The screen is glass, so when using force to lift the screen, be cautious of cracked glass and stray shards of glass coming off.
    • You have to be extra careful to dig deep enough, so you lift the entire screen unit!
  2. Motorola Moto G7 Speaker Replacement: adım 2, 1 resimden 1.
    • Excessive glass and adhesive around the edges should be removed with the spudger.
    • The glass is black and may blend in with edges of the device. Be cautious using bare hands when moving the device.
  3. Motorola Moto G7 Speaker Replacement: adım 3, 2 resimden 1. Motorola Moto G7 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove three 2.7mm T3 Torx screws from the metal piece to the right of the battery.
  4. Motorola Moto G7 Speaker Replacement: adım 4, 3 resimden 1. Motorola Moto G7 Speaker Replacement: adım 4, 3 resimden 2. Motorola Moto G7 Speaker Replacement: adım 4, 3 resimden 3.
    • Use a spudger to gently take off the metal piece that was held down by the screws.
    • A second metal piece is held under the first. This can also be popped off by using the spudger and nudging it under the metal piece connected to the band.
  5. Motorola Moto G7 Speaker Replacement, Speaker: adım 5, 3 resimden 1. Motorola Moto G7 Speaker Replacement, Speaker: adım 5, 3 resimden 2. Motorola Moto G7 Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • Remove three 3.7mm T3 Torx screws from the bottom of the phone.
    • Use the spudger to gently lift the speaker out of the phone.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Peter Nelson
742 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G6, White Winter 2020 Cal Poly, Team S19-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S19G6
4 Üyeler
20 adet Kılavuz yazıldı
Bir Yorum
Could you perhaps offer any advice on how to source one of these bottom-ported speakers?
Kevin Lettelleir - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 53
Her zaman: 4,370
