Ana içeriğe geç
Motorola Moto Q Back Casing Replacement
Neye ihtiyacın var
  1. Motorola Moto Q Back Casing Replacement, Back Casing: adım 1, 1 resimden 1.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Back Casing Replacement: adım 2, 1 resimden 1.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Back Casing Replacement: adım 3, 2 resimden 1. Motorola Moto Q Back Casing Replacement: adım 3, 2 resimden 2.
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Back Casing Replacement: adım 4, 2 resimden 1. Motorola Moto Q Back Casing Replacement: adım 4, 2 resimden 2.
    • Gently lift and remove the back casing.
Sonuç
Luis Herrera
52 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G33
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 5
Her zaman: 5,147
