Ana içeriğe geç
Motorola Moto Q Camera Replacement
Neye ihtiyacın var
  1. Motorola Moto Q Camera Replacement, Back Casing: adım 1, 1 resimden 1.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Camera Replacement: adım 2, 1 resimden 1.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Camera Replacement: adım 3, 2 resimden 1. Motorola Moto Q Camera Replacement: adım 3, 2 resimden 2.
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Camera Replacement: adım 4, 2 resimden 1. Motorola Moto Q Camera Replacement: adım 4, 2 resimden 2.
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Camera Replacement, Camera: adım 5, 2 resimden 1. Motorola Moto Q Camera Replacement, Camera: adım 5, 2 resimden 2.
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Camera Replacement: adım 6, 2 resimden 1. Motorola Moto Q Camera Replacement: adım 6, 2 resimden 2.
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Camera Replacement: adım 7, 2 resimden 1. Motorola Moto Q Camera Replacement: adım 7, 2 resimden 2.
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Camera Replacement: adım 8, 2 resimden 1. Motorola Moto Q Camera Replacement: adım 8, 2 resimden 2.
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dave Uth
35 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G33
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,929
