Ana içeriğe geç
Motorola Moto Q Keyboard Replacement
Neye ihtiyacın var
  1. Motorola Moto Q Keyboard Replacement, Back Casing: adım 1, 1 resimden 1.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Keyboard Replacement: adım 2, 1 resimden 1.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Keyboard Replacement: adım 3, 2 resimden 1. Motorola Moto Q Keyboard Replacement: adım 3, 2 resimden 2.
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Keyboard Replacement: adım 4, 2 resimden 1. Motorola Moto Q Keyboard Replacement: adım 4, 2 resimden 2.
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Keyboard Replacement, Camera: adım 5, 2 resimden 1. Motorola Moto Q Keyboard Replacement, Camera: adım 5, 2 resimden 2.
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Keyboard Replacement: adım 6, 2 resimden 1. Motorola Moto Q Keyboard Replacement: adım 6, 2 resimden 2.
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Keyboard Replacement: adım 7, 2 resimden 1. Motorola Moto Q Keyboard Replacement: adım 7, 2 resimden 2.
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Keyboard Replacement: adım 8, 2 resimden 1. Motorola Moto Q Keyboard Replacement: adım 8, 2 resimden 2.
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q Keyboard Replacement, Keyboard: adım 9, 3 resimden 1. Motorola Moto Q Keyboard Replacement, Keyboard: adım 9, 3 resimden 2. Motorola Moto Q Keyboard Replacement, Keyboard: adım 9, 3 resimden 3.
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
Sonuç
Luis Herrera
52 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 üyesi
CPSU-MANESS-W10S16G33
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 4,096
