Giriş
Use this guide to replace the LCD Display on your Motorola Moto Q.
Aletler
Parçalar
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
Bir başkası bu kılavuzu tamamladı.
