Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Insert the eject pin into the hole inside of the port and push to open a gap between back cover and frame.
Place the guitar pick into the gap.
Slide the guitar pick to cut the adhesive sticker under the cover. It's a little strong. Finally, peel off the soft back cover.
Release the side button flex connector and battery connector respectively under the rubber cover.
Twist off all 18 screws on the middle housing and remove it easily.
Pry up the motherboard and remove it carefully. At that time, we can separate the LCD screen from motherboard and get it alone.
8 Yorum
When I reassembled my Moto X 2nd gen. after a battery change, I lost audio to the speaker. Audio jack works fine. Nothing is torn, but definitely something loose or not connected. I don't know where to look. Could you please help guide me to where it might be? Thanks!
I have a solution to the speaker not working after putting the phone back together.
The speaker wasn't connecting with the metal tabs on the phone back panel due to my replacement battery being a little thicker.
I was able to bend the speaker contact pins to connects with the relevant connectors and it started working. Slightly hacky but worked. I have posted pictures https://plus.google.com/+BenSycha/posts/...
@wasrel Where did you purchase a replaccement battery and was it new?
Same problem. What is the answer?
