Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the back cover of your Motorola Moto X.
Neye ihtiyacın var
Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
Remove the SIM card tray.
Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
Slide the plastic opening tool along the seam toward the upper corner.
Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
Use the flat end of a spudger to gently pry between the flash assembly and back cover to separate the adhesive.
Remove the flash assembly from the back cover.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto X Answers community for troubleshooting help.
51 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Hey I'm looking at replacing my rear battery door cover, because white gets dirty too quick (esp. Since I work at a bike shop). Looking at replacement covers available, it seems to be that there's a lack of the camera lens protector as seen on the original battery cover. How do I go about removing this, to transfer it to the new cover?
I used a guitar pick and my thumbnail to detach the plastic. Then I used a hair dryer gun at low temp carefully to loosen the glue (which is actually only at the top and bottom of the phone. Just be cautious removing the back since you need to detach the ribbon cable from the flash. Once it was removed, I used the case opener tool to gently lift the flash assembly loose, leaving the grey adhesive on the case back. After the flash was removed,I used an Xacto blade to start to remove the adhesive which peeled off relatively easily, and was then stuck back on to the flash. There is a clear silicon type of "gasket" on the case back that will also peel off easily, so I transferred that to my new case back and stuck the flash in its place. The lens cover was the same.. just a little adhesive on the outer ring. I just put some pressure with my finger on the front side, and it popped out, adhesive still intact. Everything checked out, so I snapped it all together again! Easy Peasy!
ozarkana -
By the way, I build bicycles too!
ozarkana -
Guide was extremely helpful in replacing my white back cover with a black one. Was a pain with that adhesive though, but got the new cover on without breaking anything, and it looks great. Thanks for the writeup.
thanks for the guide. I’d like to substitute my back cover because it is damaged. I found the cover on parts4repair.com but it doesn’t have the adesive on the back, it’s just the cover. Is this a problem after the installation? Can I buy this cover and use it? thanks in advance for any help
