Ana içeriğe geç
Motorola Moto X Headphone Jack/Speaker Assembly Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: adım 1, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: adım 1, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, SIM Card: adım 1, 3 resimden 3.
    • Insert the SIM card eject tool into the hole in the side of the SIM card tray and push to eject the tray.
    • Remove the SIM card tray.
    • If the SIM card does not fall free from the tray on its own, simply remove it with your fingers.
  2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: adım 2, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: adım 2, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Back Cover Assembly: adım 2, 3 resimden 3.
    • In the following steps you will be releasing the clips holding the phone's cases together. However, the back case is also secured with an adhesive pad. After separating the clips you will use an iOpener to allow the case to fully open. Do not attempt to fully open the phone before loosening the adhesive.
    • Insert a plastic opening tool into the seam between the front and rear covers near the SIM card slot.
    • Slide the plastic opening tool along the seam toward the upper corner.
  3. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 3, 2 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 3, 2 resimden 2.
    • Carefully slide the plastic opening tool around the corner, freeing it from clips.
  4. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 4, 2 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 4, 2 resimden 2.
    • Pry around the top right corner of the phone between the two covers.
  5. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 5, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 5, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 5, 3 resimden 3.
    • Run the opening tool along the seam around all four sides, separating the remaining clips holding the cover on.
    • The plastic on the front cover is thinner near the buttons, and the buttons may move around. Go slowly to avoid damaging the buttons or the front cover.
    • Do not push the opening tool deep into phone, or you may damage internal components.
  6. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 6, 1 resimden 1.
    • Heat an iOpener and lay it over the phone for approximately 90 seconds to loosen the adhesive securing the back cover.
  7. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 7, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 7, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 7, 3 resimden 3.
    • Starting from the SIM slot side, carefully peel the back cover off of the phone.
    • The back cover is very flexible, but you don't want to damage any internal components by being too hasty.
    • There is a chance that the NFC coil may remain stubbornly adhered to the back cover. If that's the case, stop peeling the cover and reapply a heated iOpener to the back cover.
    • Do not separate the back cover entirely; it is still connected to the phone by the camera flash cable.
    • The flash cable is attached on the power/volume button side of the phone.
  8. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 8, 1 resimden 1.
    • Gently set the back cover down in a way that exposes the camera flash cable connector, but does not put strain on it.
  9. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 9, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 9, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 9, 3 resimden 3.
    • Use the tip of a spudger to flip up the retaining flap on the flash cable ZIF connector.
    • Be sure to pry only on the flap itself, not on the connector.
    • Pull the flash cable straight out of its socket.
  10. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 10, 1 resimden 1.
    • Separate the back cover from the phone.
  11. Motorola Moto X Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: adım 11, 1 resimden 1.
    • Remove the five 3 mm T3 Torx screws from the headphone jack/speaker assembly.
  12. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 12, 3 resimden 1. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 12, 3 resimden 2. Motorola Moto X Headphone Jack/Speaker Assembly Replacement: adım 12, 3 resimden 3.
    • Insert a spudger under the panhandle of the headphone jack/speaker assembly and pry it up from its recess.
    • Remove the headphone jack/speaker assembly.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
471.983 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.706 adet Kılavuz yazıldı
1Rehber Yorum
Is this the signal antenna?
I have one that says Searching for service and no matter what it won’t detect any network.
Not sure if this or the lower antenna are responsible for cellular signal.
Rafael B - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 5,854
