Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The display assembly for the Motorola Moto Z2 Force includes the front facing camera flash and the fingerprint sensor. The fingerprint sensor is very difficult to remove from the display assembly and will most likely end up damaging the screen, so it may be a good idea to replace the entire assembly should the sensor malfunction.
Neye ihtiyacın var
Place the phone on a flat surface with the screen facing up.
Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
Pry open part of the screen by pulling the tool and the screen toward you.
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
17 farklı kişi bu kılavuzu tamamladı.
14 Yorum
lol exactly what i was thinking, john!!
like what the !&&*….guide us thru removing the entire screen and then just leave us with our d in our hand lol
Just do the same thing backwards.
Can I use a z2 play screen on the z2 force?
You can but they have a big difference the LCD pixelation. The Z2 Force has 2,560x1,440 pixel resolution while the play has a 1,920x1,080 resolution. So even thought it can be done it is not recommended.
