Ana içeriğe geç
Motorola Nextel i880 Key Pad Replacement
Neye ihtiyacın var
  1. Motorola Nextel i880 Key Pad Replacement, Key Pad: adım 1, 1 resimden 1.
    • Remove the back cover by sliding the clip and lifting up the bottom of the cover.
  2. Motorola Nextel i880 Key Pad Replacement: adım 2, 2 resimden 1. Motorola Nextel i880 Key Pad Replacement: adım 2, 2 resimden 2.
    • Remove screws 1 through 4.
  3. Motorola Nextel i880 Key Pad Replacement: adım 3, 1 resimden 1.
    • Once all four screws are removed, you should be able to pop off the back half of the phone.
  4. Motorola Nextel i880 Key Pad Replacement: adım 4, 1 resimden 1.
    • Flip the logic board up to reveal the back of the keypad.
  5. Motorola Nextel i880 Key Pad Replacement: adım 5, 1 resimden 1.
    • Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
  6. Motorola Nextel i880 Key Pad Replacement: adım 6, 1 resimden 1.
    • Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
    • Secure the rest of the key pad.
  7. Motorola Nextel i880 Key Pad Replacement: adım 7, 1 resimden 1.
    • Put the logic board back into place and reattach cable number 1.
  8. Motorola Nextel i880 Key Pad Replacement: adım 8, 1 resimden 1.
    • Snap the front and back of the phone back together and reinsert screws 1 through 4.
Sonuç
Danielle Matthews
127 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 üyesi
UMASSD-VIJAYBHASKAR-F14S6G7
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 136
