Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
If you are unable to hear from the speaker, then the speaker may be faulty. This is a guide on how to replace the speaker.
  1. Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers. Lift the back cover from the bottom and remove it from the phone.
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward. Remove the battery from your phone.
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Hemen Alışveriş Yapın
  4. Remove all five screw covers with tweezers located in the picture. Remove all five screw covers with tweezers located in the picture. Remove all five screw covers with tweezers located in the picture.
    • Remove all five screw covers with tweezers located in the picture.
  5. Remove the 10 T4 Torx screws securing the midframe to the display assembly. Gently pry the midframe from the display assembly and remove it. Gently pry the midframe from the display assembly and remove it.
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
  6. Locate the speaker on the back of the midframe.
    • Locate the speaker on the back of the midframe.
  7. The speaker is attached to the midframe with adhesive. Remove carefully. Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • The speaker is attached to the midframe with adhesive. Remove carefully.
    • Use the Metal Spudger to get between the speaker and the midframe and slowly lift the speaker upwards.
    • Remove the speaker from the midframe.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Elizabeth Lee
92 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team 8-6, Leahy Fall 2014 USF Tampa, Team 8-6, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 323
