Ana içeriğe geç
Motorola Q Global Camera Replacement
Neye ihtiyacın var
  1. Motorola Q Global Camera Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Camera Replacement: adım 2, 2 resimden 1. Motorola Q Global Camera Replacement: adım 2, 2 resimden 2.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Camera Replacement, Camera: adım 3, 1 resimden 1.
    • Press inward on the upper casing.
  4. Motorola Q Global Camera Replacement: adım 4, 1 resimden 1.
    • Slide the upper case to the right and lift up.
    • Lift the camera sticker so that it doesn't get damaged.
  5. Motorola Q Global Camera Replacement: adım 5, 2 resimden 1. Motorola Q Global Camera Replacement: adım 5, 2 resimden 2.
    • Remove the six labeled screws with a T5 Torx Screwdriver.
  6. Motorola Q Global Camera Replacement: adım 6, 1 resimden 1.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Camera Replacement: adım 7, 2 resimden 1. Motorola Q Global Camera Replacement: adım 7, 2 resimden 2.
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Camera Replacement: adım 8, 2 resimden 1. Motorola Q Global Camera Replacement: adım 8, 2 resimden 2.
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Camera Replacement: adım 9, 1 resimden 1.
    • Use the plastic opening tool to lift the camera from the phone.
  10. Motorola Q Global Camera Replacement: adım 10, 1 resimden 1.
    • The new camera can now be attached to the motherboard.
Sonuç
Ekip
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G31
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 678
