Ana içeriğe geç
Motorola Q Global Display screen Replacement
Neye ihtiyacın var
  1. Motorola Q Global Display screen Replacement, Battery: adım 1, 2 resimden 1. Motorola Q Global Display screen Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola Q Global Display screen Replacement: adım 2, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola Q Global Display screen Replacement, Display screen: adım 3, 1 resimden 1.
    • Press inwardly on the upper casing to release.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola Q Global Display screen Replacement: adım 4, 1 resimden 1.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola Q Global Display screen Replacement: adım 5, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 5, 2 resimden 2.
    • Remove the 6 screws using the T5 torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola Q Global Display screen Replacement: adım 6, 1 resimden 1.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola Q Global Display screen Replacement: adım 7, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 7, 2 resimden 2.
    • Remove both screws on the mounted surface with a T5 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola Q Global Display screen Replacement: adım 8, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 8, 2 resimden 2.
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola Q Global Display screen Replacement: adım 9, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 9, 2 resimden 2.
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
    FixBot'a Sor
    Yorum Ekle
  10. Motorola Q Global Display screen Replacement: adım 10, 2 resimden 1. Motorola Q Global Display screen Replacement: adım 10, 2 resimden 2.
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
    FixBot'a Sor
    Yorum Ekle
  11. Motorola Q Global Display screen Replacement: adım 11, 1 resimden 1.
    • Insert the new LCD screen into the circuit.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Will Dickman
28 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G31
5 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 37
Her zaman: 1,145
