Ana içeriğe geç
Motorola Q Global Speakers Replacement
Neye ihtiyacın var
  1. Motorola Q Global Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Speakers Replacement: adım 2, 2 resimden 1. Motorola Q Global Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Speakers Replacement, Speakers: adım 3, 1 resimden 1.
    • Press inwardly on the upper casing until it pops out of the phone.
  4. Motorola Q Global Speakers Replacement: adım 4, 1 resimden 1.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Speakers Replacement: adım 5, 2 resimden 1. Motorola Q Global Speakers Replacement: adım 5, 2 resimden 2.
    • Remove the six labeled screws with a T5 torx screw driver.
  6. Motorola Q Global Speakers Replacement: adım 6, 1 resimden 1.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Speakers Replacement: adım 7, 1 resimden 1.
    • Remove the speakers by using the plastic remover tool.
  8. Motorola Q Global Speakers Replacement: adım 8, 1 resimden 1.
    • Insert the new speakers by gently pressing them down into place.
Sonuç
Ekip
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G31
5 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 645
