Ana içeriğe geç
Motorola Q700 Sidekick Speaker and Camera Replacement
Neye ihtiyacın var
  1. Motorola Q700 Sidekick Speaker and Camera Replacement, Phone: adım 1, 1 resimden 1.
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 2, 1 resimden 1.
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 3, 1 resimden 1.
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 4, 1 resimden 1.
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 5, 1 resimden 1.
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 6, 1 resimden 1.
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 7, 1 resimden 1.
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Speaker and Camera Replacement, Speaker and Camera: adım 8, 1 resimden 1.
    • complete dissassembly as instructed by guide
  9. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 9, 1 resimden 1.
    • Remove camera piece from casing
  10. Motorola Q700 Sidekick Speaker and Camera Replacement: adım 10, 1 resimden 1.
    • replace with new camera piece into casing and reassemble by reversing dissemble procedure
Sonuç
Rich
125 İtibar
6 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013 üyesi
SUNYCORT-GETTO-S13S1G4
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 210
