Giriş
The battery is located between the back of the phone and the motherboard, making it necessary to remove the motherboard to access the battery. This guide involves the removal of various screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
Neye ihtiyacın var
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Remove the plastic yellow tape on the battery connector using the spudger.
Pry up on the orange connection to release it from the motherboard.
12 farklı kişi bu kılavuzu tamamladı.
