Ana içeriğe geç
Motorola RAZR Maxx HD Circuit Board Replacement
Neye ihtiyacın var
  1. Motorola RAZR Maxx HD Circuit Board Replacement, Screen Removal: adım 1, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement, Screen Removal: adım 1, 2 resimden 2.
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Circuit Board Replacement: adım 2, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 2, 2 resimden 2.
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Circuit Board Replacement: adım 3, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 3, 2 resimden 2.
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Circuit Board Replacement: adım 4, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 4, 2 resimden 2.
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Circuit Board Replacement, Circuit Board: adım 5, 3 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement, Circuit Board: adım 5, 3 resimden 2. Motorola RAZR Maxx HD Circuit Board Replacement, Circuit Board: adım 5, 3 resimden 3.
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
  6. Motorola RAZR Maxx HD Circuit Board Replacement: adım 6, 1 resimden 1.
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
  7. Motorola RAZR Maxx HD Circuit Board Replacement: adım 7, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
  8. Motorola RAZR Maxx HD Circuit Board Replacement: adım 8, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 8, 2 resimden 2.
    • Using tweezers, remove the back facing camera cover.
  9. Motorola RAZR Maxx HD Circuit Board Replacement: adım 9, 2 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 9, 2 resimden 2.
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  10. Motorola RAZR Maxx HD Circuit Board Replacement: adım 10, 1 resimden 1.
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
  11. Motorola RAZR Maxx HD Circuit Board Replacement: adım 11, 3 resimden 1. Motorola RAZR Maxx HD Circuit Board Replacement: adım 11, 3 resimden 2. Motorola RAZR Maxx HD Circuit Board Replacement: adım 11, 3 resimden 3.
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Anna Sullivan
880 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G40
5 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
so i have an old XT912 and i thought the other day it would be cool to have it running linux
however the device has a broken power button
actually no power button was too rough with it back in the when i had little knowledge about opening phones
the button is gone lol i remember using using a small screw driver to get it to respond a few times and it just stopped after a while
i think i dug it right off the board do you thinks its worth it to attempt to fix it or is there another way to get it to respond to power
>>>>>>>>>(-_//)
Jerome Bailey - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,134
