Giriş
Removal of the motherboard is necessary to access the rear facing camera. This guide involves the removal of various screws and parts so make sure you are in a clean and organized environment to avoid the loss of any components.
Neye ihtiyacın var
Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
Using a T5 Torx screwdriver, unscrew the two 4.0mm screws on the rear-facing camera cover.
2 farklı kişi bu kılavuzu tamamladı.
