Ana içeriğe geç
Motorola RAZR Maxx HD Screen Replacement
Neye ihtiyacın var
  1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: adım 1, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement, Screen Removal: adım 1, 2 resimden 2.
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola RAZR Maxx HD Screen Replacement: adım 2, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 2, 2 resimden 2.
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola RAZR Maxx HD Screen Replacement: adım 3, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 3, 2 resimden 2.
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola RAZR Maxx HD Screen Replacement: adım 4, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 4, 2 resimden 2.
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola RAZR Maxx HD Screen Replacement, Front-Facing Camera: adım 5, 1 resimden 1.
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola RAZR Maxx HD Screen Replacement: adım 6, 3 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 6, 3 resimden 2. Motorola RAZR Maxx HD Screen Replacement: adım 6, 3 resimden 3.
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola RAZR Maxx HD Screen Replacement: adım 7, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola RAZR Maxx HD Screen Replacement, Earpiece Speaker: adım 8, 1 resimden 1.
    • Insert the spudger between the speaker and retaining clip and gently pry upward to release the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  9. Motorola RAZR Maxx HD Screen Replacement: adım 9, 2 resimden 1. Motorola RAZR Maxx HD Screen Replacement: adım 9, 2 resimden 2.
    • Using a spudger, gently pry up on the lower right edge of the black earpiece speaker ribbon cable, attached to the screen, to release it from the LCD display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Enrique
371 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S8G40
5 Üyeler
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 28
Her zaman: 3,193
