Ana içeriğe geç
Motorola RAZR2 v9m Back Housing Replacement
Neye ihtiyacın var
  1. Motorola RAZR2 v9m Back Housing Replacement, Battery: adım 1, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement, Battery: adım 1, 2 resimden 2.
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
  2. Motorola RAZR2 v9m Back Housing Replacement: adım 2, 3 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 2, 3 resimden 2. Motorola RAZR2 v9m Back Housing Replacement: adım 2, 3 resimden 3.
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
  3. Motorola RAZR2 v9m Back Housing Replacement: adım 3, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 3, 2 resimden 2.
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
  4. Motorola RAZR2 v9m Back Housing Replacement: adım 4, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 4, 2 resimden 2.
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
  5. Motorola RAZR2 v9m Back Housing Replacement, Flip-stop Bumper Pad: adım 5, 3 resimden 1. Motorola RAZR2 v9m Back Housing Replacement, Flip-stop Bumper Pad: adım 5, 3 resimden 2. Motorola RAZR2 v9m Back Housing Replacement, Flip-stop Bumper Pad: adım 5, 3 resimden 3.
    • Gently press the pointy end of the spudger into the edge of the bumper until it bows and separates from the phone.
    • The bumper is held in place with adhesive. If you plan on reusing the bumper, then use clean tools to keep the surface sticky.
    • Grab the bowed portion of bumper. Gently lift and peel the bumper away from the phone.
    • Remember that the bumper will be sticky. Place it somewhere clean if you will be reusing it.
  6. Motorola RAZR2 v9m Back Housing Replacement, Back Housing: adım 6, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement, Back Housing: adım 6, 2 resimden 2.
    • Remove the two 4-mm T5 Torx screws, previously hidden beneath the flip stop bumper pad.
  7. Motorola RAZR2 v9m Back Housing Replacement: adım 7, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 7, 2 resimden 2.
    • Close the phone and flip it onto its back.
    • Remove the two 4-mm T5 Torx screws.
  8. Motorola RAZR2 v9m Back Housing Replacement: adım 8, 2 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 8, 2 resimden 2.
    • Wedge the spudger about 4 mm into the gap between the phone casing and the rear housing.
    • Pry the rear housing away from the phone until enough is exposed to grasp with your fingers.
  9. Motorola RAZR2 v9m Back Housing Replacement: adım 9, 3 resimden 1. Motorola RAZR2 v9m Back Housing Replacement: adım 9, 3 resimden 2. Motorola RAZR2 v9m Back Housing Replacement: adım 9, 3 resimden 3.
    • Tilt the loosened half of the rear housing away from the phone. The housing should easily separate after tilting it about 45 degrees away from the phone.
    • A small rubber cap (marked in red on the third image) loosely sits on the motherboard. It can easily fall off when removing the rear housing. Take care not to lose it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 971
