Ana içeriğe geç
Motorola RAZR2 v9m Keypad Replacement
Neye ihtiyacın var
  1. Motorola RAZR2 v9m Keypad Replacement, Battery: adım 1, 2 resimden 1. Motorola RAZR2 v9m Keypad Replacement, Battery: adım 1, 2 resimden 2.
    • Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
    FixBot'a Sor
    Yorum Ekle
  2. Motorola RAZR2 v9m Keypad Replacement: adım 2, 3 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 2, 3 resimden 2. Motorola RAZR2 v9m Keypad Replacement: adım 2, 3 resimden 3.
    • Pinch the top and bottom edges of the panel and pull it away from the RAZR2.
    • The rear panel uses four small hooks to hold it in place. If the panel will not easily pull away, slide the panel more toward the hinge.
    FixBot'a Sor
    Yorum Ekle
  3. Motorola RAZR2 v9m Keypad Replacement: adım 3, 2 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 3, 2 resimden 2.
    • Gently pull the white plastic tab to lift the battery away from the RAZR2.
    • The white plastic tab is attached to the phone. Only pull it enough to expose the edges of the battery.
    FixBot'a Sor
    Yorum Ekle
  4. Motorola RAZR2 v9m Keypad Replacement: adım 4, 2 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 4, 2 resimden 2.
    • To remove the battery, grasp its edges pull away from the phone.
    • When installing a new battery, be sure the metal contacts on the phone line up with the ones on the battery.
    FixBot'a Sor
    Yorum Ekle
  5. Motorola RAZR2 v9m Keypad Replacement, Keypad: adım 5, 3 resimden 1. Motorola RAZR2 v9m Keypad Replacement, Keypad: adım 5, 3 resimden 2. Motorola RAZR2 v9m Keypad Replacement, Keypad: adım 5, 3 resimden 3.
    • Flip the RAZR2 open with the battery compartment facing you.
    • Pull the white battery tab away from the phone to reveal a small black gap in the battery compartment.
    • Place the spudger into this gap. Rest the spudger against the black plastic inside of the gap.
    FixBot'a Sor
    Yorum Ekle
  6. Motorola RAZR2 v9m Keypad Replacement: adım 6, 3 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 6, 3 resimden 2. Motorola RAZR2 v9m Keypad Replacement: adım 6, 3 resimden 3.
    • Rest the spudger/scewdriver between the top of the black plastic and the metal body of the phone and leaver the two apart to release the top clip on the keyboard.and the top of the keypad pops out from the RAZR2.
    FixBot'a Sor
    Yorum Ekle
  7. Motorola RAZR2 v9m Keypad Replacement: adım 7, 3 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 7, 3 resimden 2. Motorola RAZR2 v9m Keypad Replacement: adım 7, 3 resimden 3.
    • Use a plastic opening tool to gently pry one side of the keypad away from the RAZR2.
    • There are 2 clips on the side of the keypad. In total, there are 8 clips holding the keypad to the phone.
    FixBot'a Sor
    Yorum Ekle
  8. Motorola RAZR2 v9m Keypad Replacement: adım 8, 3 resimden 1. Motorola RAZR2 v9m Keypad Replacement: adım 8, 3 resimden 2. Motorola RAZR2 v9m Keypad Replacement: adım 8, 3 resimden 3.
    • Lift the keypad away from the phone.
    • When reassembling, gently squeeze the sides of the keypad until the keypad has a slight bow running down the middle from top to bottom, like a playing card. This will ensure that it slides easily into place. Take care not to damage any of the 8 clips.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 1,712
