Giriş
Use this repair guide to replace a motherboard in a Motorola RAZR2 v9m.
Neye ihtiyacın var
Push the rear cover toward the hinge of the RAZR2. The panel will slide about 3 mm.
Gently press the pointy end of the spudger into the edge of the bumper until it bows and separates from the phone.
Grab the bowed portion of bumper. Gently lift and peel the bumper away from the phone.
Remove the two 4-mm T5 Torx screws, previously hidden beneath the flip stop bumper pad.
Use a pair of tweezers or your fingers to remove the small rubber cap from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
