Ana içeriğe geç
Motorola RIZR Z3 LCD Replacement
Neye ihtiyacın var
    1. Motorola RIZR Z3 LCD Replacement, Battery: adım 1, 2 resimden 1. Motorola RIZR Z3 LCD Replacement, Battery: adım 1, 2 resimden 2.
      • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola RIZR Z3 LCD Replacement: adım 2, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 2, 2 resimden 2.
      • Tilt the battery by lifting at the exposed notch.
      • Slide the battery out of its casing.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola RIZR Z3 LCD Replacement, Motherboard: adım 3, 1 resimden 1.
      • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola RIZR Z3 LCD Replacement: adım 4, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 4, 2 resimden 2.
      • Use a plastic opening tool to lift the plastic casing.
      • Pull the plastic casing directly away from the phone.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola RIZR Z3 LCD Replacement: adım 5, 1 resimden 1.
      • Lift the black rubber loudspeaker housing up and out of the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola RIZR Z3 LCD Replacement: adım 6, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 6, 2 resimden 2.
      • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
      • Caution: Remove carefully, if broken, the phone will not be able to make calls.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola RIZR Z3 LCD Replacement: adım 7, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 7, 2 resimden 2.
      • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
      • Caution: Remove carefully, if broken, the phone will not function properly.
      FixBot'a Sor
      Yorum Ekle
    6. Motorola RIZR Z3 LCD Replacement: adım 8, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 8, 2 resimden 2.
      • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
      • Caution: Do this gently Unclipping too fast may cause damage to your phone.
      FixBot'a Sor
      Yorum Ekle
    1. Motorola RIZR Z3 LCD Replacement, LCD: adım 9, 1 resimden 1.
      • Turn the phone to the front.
      • Push the keypad out through the plastic casing.
      FixBot'a Sor
      Yorum Ekle
    2. Motorola RIZR Z3 LCD Replacement: adım 10, 1 resimden 1.
      • Turn the phone to the side.
      • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
      FixBot'a Sor
      Yorum Ekle
    3. Motorola RIZR Z3 LCD Replacement: adım 11, 1 resimden 1.
      • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
      FixBot'a Sor
      Yorum Ekle
    4. Motorola RIZR Z3 LCD Replacement: adım 12, 3 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 12, 3 resimden 2. Motorola RIZR Z3 LCD Replacement: adım 12, 3 resimden 3.
      • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
      • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
      • Caution: Do this carefully, damage to this ribbon cable will cause a blank screen.
      • Pull the plastic screen casing directly away from the LCD unit.
      FixBot'a Sor
      Yorum Ekle
    5. Motorola RIZR Z3 LCD Replacement: adım 13, 2 resimden 1. Motorola RIZR Z3 LCD Replacement: adım 13, 2 resimden 2.
      • Use a spudger to lift the LCD partially away from the metal casing.
      • Use the spudger to pry the ribbon cable directly up from its clip on the metal casing.
      • Caution: Damage to the ribbon cable here will cause screen damage.
      • Pull the LCD completely away from the metal casing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Brooke Shuford
65 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G34
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 1,320
