Ana içeriğe geç
Motorola RIZR Z3 Motherboard Replacement
Neye ihtiyacın var
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: adım 1, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Motherboard Replacement: adım 2, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement: adım 2, 2 resimden 2.
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Motherboard Replacement: adım 4, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement: adım 4, 2 resimden 2.
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Motherboard Replacement: adım 5, 1 resimden 1.
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Motherboard Replacement: adım 6, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement: adım 6, 2 resimden 2.
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Motherboard Replacement: adım 7, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Motherboard Replacement: adım 8, 2 resimden 1. Motorola RIZR Z3 Motherboard Replacement: adım 8, 2 resimden 2.
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
Sonuç
Andrew Brock
8 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 üyesi
CPSU-AMIDO-F11S5G34
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 1,335
