Ana içeriğe geç
Motorola Razr 40 Ultra Screen Protector Replacement
Neye ihtiyacın var
  1. Motorola Razr 40 Ultra Screen Protector Replacement, Secure your phone: adım 1, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Secure your phone: adım 1, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Secure your phone: adım 1, 3 resimden 3.
    • Completely open your phone and unplug any cables.
    • Place your phone in the alignment adapter screen-side up, with the charging port facing the raised posts.
  2. Motorola Razr 40 Ultra Screen Protector Replacement, Create a shim: adım 2, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Create a shim: adım 2, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Create a shim: adım 2, 3 resimden 3.
    • In this step, you'll create a shim to separate the old screen protector from your phone's screen.
    • Use scissors to cut a small square (about the size of your thumbnail) out of your replacement screen protector liner, just between the two long cutouts on the bottom edge.
  3. Motorola Razr 40 Ultra Screen Protector Replacement, Separate the screen protector from the screen: adım 3, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Separate the screen protector from the screen: adım 3, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Separate the screen protector from the screen: adım 3, 3 resimden 3.
    • Slide the sharpest corner of your shim under one of the top corners of your screen protector.
    • It might take a few tries to separate the protector from the screen. If it feels stubborn, cut a new edge on your shim and try again.
  4. Motorola Razr 40 Ultra Screen Protector Replacement, Grip the screen protector: adım 4, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Grip the screen protector: adım 4, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Grip the screen protector: adım 4, 3 resimden 3.
    • Insert your shim deeper under the corner of the protector until you can grip it with your fingers.
  5. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the screen protector: adım 5, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the screen protector: adım 5, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the screen protector: adım 5, 3 resimden 3.
    • Peel and remove the old screen protector.
  6. Motorola Razr 40 Ultra Screen Protector Replacement, Prepare your workspace: adım 6, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Prepare your workspace: adım 6, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Prepare your workspace: adım 6, 3 resimden 3.
    • Have your replacement screen protector and roller within reach—you'll be holding the protector up with one hand and won't be able to let go to reposition or grab a tool.
    • Orient the replacement protector so that the oval cutout is on the top right, and the long cutouts are toward the bottom of the phone.
  7. Motorola Razr 40 Ultra Screen Protector Replacement, Clean your screen: adım 7, 2 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Clean your screen: adım 7, 2 resimden 2.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to your screen.
    • Use a microfiber or lint free cloth to wipe away any smudges or dust.
  8. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the protective liner: adım 8, 2 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the protective liner: adım 8, 2 resimden 2.
    • Hold the replacement screen protector with its liner pull tab facing down. Keep the film facing down to prevent dust from settling onto the sticky side.
    • Peel and fully remove the protective liner from the underside of the protector.
    • During the next two steps, don't set the protector down or wait for an extended period of time—as soon as the adhesive is exposed, it'll slowly attract dust.
  9. Motorola Razr 40 Ultra Screen Protector Replacement, Align the screen protector: adım 9, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Align the screen protector: adım 9, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Align the screen protector: adım 9, 3 resimden 3.
    • Make sure no dust settled on your phone's screen since you cleaned it. Any dust or smudges will prevent the protector from adhering. If dust does settle, lift the protector slightly and wipe the screen down again.
    • Slide the top circle and oval cutouts over the hooks on the upper alignment posts.
    • Gently pull the replacement protector over the screen and onto the lower alignment posts. Don't let the film touch the screen just yet.
  10. Motorola Razr 40 Ultra Screen Protector Replacement, Apply the screen protector: adım 10, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Apply the screen protector: adım 10, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Apply the screen protector: adım 10, 3 resimden 3.
    • During this step, keep the roller in contact with the screen. If you stop rolling and start somewhere else, creases might form under the protector.
    • Hold the protector tight over the lower alignment posts.
    • Use the roller to firmly roll the protector onto the top half of the screen, starting from the top edge.
    • When you reach the middle of the screen, lift the remaining half of the liner to a 45-degree angle.
    • Increase pressure on the roller and slowly roll across the hinge area of the screen.
    • When you pass the middle of the screen, lower the liner and finish rolling the bottom half of the protector onto the screen.
  11. Motorola Razr 40 Ultra Screen Protector Replacement, Secure the screen protector: adım 11, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Secure the screen protector: adım 11, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Secure the screen protector: adım 11, 3 resimden 3.
    • Use the squeegee or a plastic card to press the top and bottom edges of the protector onto the screen.
    • Press around the perimeter of the screen, working out any bubbles toward the edges as you go.
  12. Motorola Razr 40 Ultra Screen Protector Replacement, Separate the upper liner: adım 12, 2 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Separate the upper liner: adım 12, 2 resimden 2.
    • Peel the top right corner of the large liner away from the screen to separate it from the screen protector.
    • Make sure the protector doesn't peel up with the liner. If it does, use the squeegee to press it down, or try the other side.
  13. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the upper liner: adım 13, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the upper liner: adım 13, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement, Remove the upper liner: adım 13, 3 resimden 3.
    • Work down the long edge of the screen, peeling up the edge of the liner as you go.
    • Once you reach the bottom of the screen, fully peel the liner off and remove it from the adapter.
  14. Motorola Razr 40 Ultra Screen Protector Replacement, Wipe away any imperfections: adım 14, 1 resimden 1.
    • Use a microfiber or lint free cloth to wipe the screen protector and rub out any streaks or imperfections between it and the screen.
    • Work out any small bubbles by wiping toward the edges. If there are any large bubbles, the screen protector didn't adhere properly and needs to be replaced.
  15. Motorola Razr 40 Ultra Screen Protector Replacement: adım 15, 3 resimden 1. Motorola Razr 40 Ultra Screen Protector Replacement: adım 15, 3 resimden 2. Motorola Razr 40 Ultra Screen Protector Replacement: adım 15, 3 resimden 3.
    • Use your squeegee or a plastic card with a cloth to firmly rub along the perimeter of the screen protector to fully secure the edges to the screen.
    • If there are any large creases, especially near the hinge, the protector didn't adhere properly and needs to be replaced.
    • Small imperfections or streaks near the top and bottom of the screen will disappear within a couple of days.
Sonuç
Clay Eickemeyer
53.455 İtibar
394 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
15.203 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 101
Her zaman: 106
