Ana içeriğe geç
Motorola Razr V3 Upper Casing Replacement
Neye ihtiyacın var
  1. Motorola Razr V3 Upper Casing Replacement, Battery: adım 1, 2 resimden 1. Motorola Razr V3 Upper Casing Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Upper Casing Replacement: adım 2, 2 resimden 1. Motorola Razr V3 Upper Casing Replacement: adım 2, 2 resimden 2.
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Upper Casing Replacement, Upper Casing: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 Upper Casing Replacement: adım 4, 1 resimden 1.
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 Upper Casing Replacement: adım 5, 1 resimden 1.
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ian Cottengim
172 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013 üyesi
CPSU-AMIDO-S13S3G46
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 3,254
